GS-Calc Help > Calculation Functions > Informational Functions
cell countBlank errorType isBlank isErr isError isEven isLogical isNA isNonText isNumber isOdd isRef isText n na type
cell(type, [reference])
Depending on the "type" value the function returns:
"address" : the specified reference as text
"col" : column number of the specified cell
"row" : row number of the specified cell
"color" : 1 if the current cell format is set to display negative numbers in red; 0 otherwise
"contents" : value of the specified cell
"filepath" : filename and full path of current document
"format" : symbol of the format code of the specified cell, as listed below
"parentheses" : 1 if the current cell format is set to display negative numbers in parentheses; 0 otherwise
"prefix" : single quotation mark (') if the cell contents is left-aligned, double quotation mark (") if the cell contents is right-aligned, caret (^) if the cell contents is centered, empty text in all other cases
"protect" : 1 if the specified cell is protected
"type" : "b" if the cell is empty, "l" if the cell contains text, "v" in all other cases
"width" : number of characters in the default font size fitting in the specified column
General    "G"
0    "F0"
#,##0    ",0"
0.00    "F2"
#,##0.00    ",2"
$#,##0_);($#,##0)    "C0"
$#,##0_);[Red]($#,##0)    "C0-"
$#,##0.00_);($#,##0.00)    "C2"
$#,##0.00_);[Red]($#,##0.00)    "C2-"
0%    "P0"
0.00%    "P2"
0.00E+00    "S2"
# ?/? or # ??/??    "G"
m/d/yy or m/d/yy h:mm or mm/dd/yy    "D4"
d-mmm-yy or dd-mmm-yy    "D1"
d-mmm or dd-mmm    "D2"
mmm-yy    "D3"
mm/dd    "D5"
h:mm AM/PM    "D7"
h:mm:ss AM/PM    "D6"
h:mm    "D9"
h:mm:ss    "D8"
=cell("address", sheet1!$a$2) returns "sheet1!$A$2"
=cell("address", sheet1!a2) returns "sheet1!A2"
=cell("width", b10) returns 9
countBlank(v1, v2, ...)
Counts empty cells and cells containing empty strings for the specified list of arguments.
=countBlank({1, 2, 3,,}, {""},,) returns 5
errorType(error)
Returns an integer representing a given error value.
For the complete list of error codes, please see the 'Data types' help topic.
isBlank(x)
Returns 1 if 'x' refers to an empty cell or an empty string, 0 otherwise.
=isBlank("") returns 1
isErr(x)
Returns 1 if 'x' is an error value except #N/A!, 0 otherwise.
=isErr(1/0) returns 1
=isErr(#SYNTAX!) returns 1
isError(x)
Returns 1 if 'x' is an error value, 0 otherwise.
=isError(#N/A!) returns 1
isEven(n)
Returns 1 if 'n' is even, 0 otherwise. All numbers are rounded to the nearest integers.
=isEven(12) returns 1
=isEven(12.6) returns 0
isLogical(n)
Returns 1 if 'n' is 1 or 0, 0 otherwise.
=isLogical(1) returns 1
isNA(error)
Returns 1 if 'error' refers to the #N/A value, 0 otherwise.
=isNA(#N/A!) returns 1
isNonText(x)
Returns 1 if 'x' refers to any value that is not a text string, 0 otherwise.
=isNonText("") returns 0
=isNonText(1) returns 1
isNumber(x)
Returns 1 if 'x' represents a number (which also includes a string that can be converted to a number), 0 otherwise.
=isNumber(9) returns 1
=isNumber("9") returns 1
isOdd(n)
Returns 1 if 'n' is odd, 0 otherwise. All numbers are rounded to the nearest integers.
=isOdd(12) returns 0
=isOdd(12.6) returns 1
isRef(x)
Returns 1 if 'x' is a reference, 0 otherwise.
=isRef(a1) returns 1
=isRef({1,2,3}) returns 0
isText(x)
Returns 1 if 'x' represents a text string, 0 otherwise.
=isText("a") returns 1
n(x)
Converts x to a number.
=n("2005") returns 2005
na()
Returns the #N/A error value.
=na() returns #N/A!
type(x)
Returns the type of x:
1 Number
2 Text
16 Error value
64 Array
=type(1) returns 1
=type({1, 2, 3}) returns 64
